- Mar 8, 2009
- 44,669
I was bored and didn't want to do glass work, so decided to do motor work
My buddy Dean has a twin engine cruiser with V-drive 454 MPI's. The Port motor has been replaced twice, get that twice. Some years ago the previous owner had the motor replaced by Merc dealer with a Reman. Motor SN 91003823 and list .030 bored, and .020 mains and Rods.
Reason motor needed to be replaced 2nd time was it spun a rod bearing. Spun bearing is most always the crank was not turned correctly and has a taper in the journal. The rod bearing spun so have had the motor in my barn for a few years.
OK, starboard motor has been having trouble with power. We do the yearly checks and the the compression is lower. Notice that there are 2 different pistons installed by rebuilder. Other then the piston and crank, all looks ok. Going to press the 2 off and measure the weight of each to compare.
Going to boil the block the block out, and motor had only about 25 hours before the bearing spun (not used much).
