- Jul 18, 2011
- 19,626
I have mentioned wanting to install solar charging to keep the (7) batteries fresh while the (CY 338) boat sits on its mooring. Today I hooked everything up (using the Whaler as a work surface) for some testing, although it was a cloudy day. The system seems to work OK, considering the lack of direct sunlight.
100 Watt Solar Panel
10 Amp regulator
3 Bank battery isolator
Through clouds it was getting 13.2 volts and 900 Milliamps (0.9a) onto a battery that was resting at 12.4 volts, so a bit low.
I'm going to give it a fun sun test (whenever the sun comes out) and see what it looks like.
The 100 watts (peak) should be plenty to spread across the 7 batteries in 3 banks on my boat. Installation may be a bit tricky . . . got to figure out a good way to mount the solar panel to the arch.
10 Amp regulator
