25hp 3cylinder starting in reverse
Ronniewhite
I have a 2000 Johnson 25hp 3cylinder. Most of the time when I start it it's in reverse. If I shift it into forward then it will shift back into neutral np. Not a big deal I just want to make sure something isn't about to go on it?
Lower unit , gear repairs are very expensive.----Explain what model you have and if water pump work was done !
Ronniewhite
J25TEL3SS. I changed the impeller but it did this before that.
Ronniewhite
So I was looking at the shifter today too see If I could see anything loose under the hood . Everything looks good. But sometimes when shifting into reverse I would have to move the prop with my foot before it fully engaged. As soon as it started to turn it would shift all the way back. Does anyone know what this means?
Simple-----Propeller must be turning when trying to shift this and many other motors.-----Allows clutch dog and gears to engage.-----Look at some pictures of these parts.
Ronniewhite
So everything is ok then?
I learned back in 1968 that prop must be turned while shifting most motors.-----I think you still need to adjust the shift rod to correct the shift issue described in post #1 in my opinion.
jimmbo
Get the correct Service Manual for your Engine.
So when you shut the Engine off, is it in Neutral, Forward, then somehow it shifts, by itself into Reverse, before you restart it?
Ronniewhite
Yes lots of times it is. The shifter looks like it's in neutral but it's not. Then put it in forward and it shifts into neutral np.
I could go out and look at a few and do some measuring.----Not going to do it as am comfortable in my chair.---Start by removing the black plastic screens.------State whether shift goes UP for forward or DOWN for forward.
Ronniewhite
Ok I will go do that right now
Do EXACTLY what I say.------Mark the lower shift rod and upper shift rod.----Disconnect shift rods making sure the 2 shift rods do not turn.--------Remove lower unit.-----Try to screw the lower shift rod into the lower unit.----If it turns , state how many turns it took to bottom it out.
