Lower Unit Compatability
psyc0tic1
I have a 1989 Mercury 115 hp 4-cylinder 2-stroke (0C100574).
I have an opportunity to purchase a complete 2000 Mercury 125 up 4-cylinder 2-stroke (0T051775) for cheap. (Motor no good, lots of good parts)
My questions are:
1) Will the lower unit on the 2000 direct bolt on my 1989? (This is the most important question)
2) Will the oil injection pump and tank/lines direct bolt on my 1989?
jimmbo
First serial number took me to a Parts listing for a 25" Shaft
The Second Serial number took me to a listing for a 4 cylinder Jet...
psyc0tic1
The first serial number can be found here:
The second serial number can be found here:
I saw the motor and have a pic of the serial... It isnt a jet. The drive shafts have the same part number
jimmbo
Yet, even your second link there states "80 Jet"
Well since you have your links, you can look up all the Parts #s to check Compatibility
psyc0tic1
Why did you bother replying? I am asking for experienced help... If you lack the experience... don't reply thank you
jimmbo
You knew how/where to look, but were just too Lazy and wanted someone else to do it for you.
psyc0tic1
Wrong... I looked but while there are some part numbers the same... Not all are and NONE of these diagrams have the dimensions etc so dude... go away and let adults talk here
jimmbo
Well, you certainly won't be participating in that Conversation/Discussion
flyingscott
let me make this simple NO they do not interchange. they also did not make 125 in 89
psyc0tic1
I never said they made a 125 in 89... The 115 is an 89 and the 125 is a 2000... As stated in the original post.
Does that mean the 2000 125 lower unit will not direct bolt on to the 89 115?
The reason I ask is because I see so many posts on the interweb saying that the lower units from 90 hp to 125 hp are interchangable but I wanted professional opinions
psyc0tic1
Let's keep it civil fellas.......
Thank you for stepping in... I see others asking this same question about other brand motors and they receive all kinds of help from nice people... somehow I am not that lucky
flyingscott
The shift rod heights are different when they went from a 3 dog jaw to a 6 I believe. It may I'd you have everything off off the donor motor.
