84 Starcraft Islander 26ft / 3.7Mercruiser rebuild
sronza
I am rebuilding an 84 Starcraft Islander.
Engine 3.7Mercruiser
Adding holley sniper
you have multiple threads on the same topic
jbcurt00
Use this topic for documenting resto work on the hull or Mods you're making to the layout.
Keep the Mercruiser motor work in your Mercruiser topic:
Best not to duplicate topics
sronza
Heres an update. Boat is going back together now. Engine is in. Floors Aluminum are in and rivets installed.
sronza
More interior floor pics
sronza
cut outs in transom to access swim platform And make boat more beach friendly.
sronza
Heres the latest.
Ive completed the wrap. Ive also been running the boat for a couple weeks now and its running pretty good.
sronza
Heres another photo
sronza
Im using the original 3.7 mercruiser.
Ive updated everything I could.
So far I like the motor. It has a lot of torque.Its. Its no speed demon but it gets up on plane immediately than cruises at 25 mph at 3500rpm.
…….but. The wiring on this boat is so bad.
the harness itself has degraded beyond explanation. The wire itself inside the harness is bad. As well as the plugs inside. At the pins.
I could write a novel on what Ive learned.
Just on wiring. If you have a 3.7 most people would probably blame engine trouble On the 3.7 when in fact it is probably bad wiring.
sronza
Heres the walk out transom mods.Swim platform is under construction now. Pics to come soon.
sronza
Heres my engine customization. I removed the water pump shaft from camshaft. I than counterbored the timing chain sprocket to accept new stainless stub shaft.this is a slide fit with less than .002“ run out. I used 318 stainless because it is hard and should stand up to seal wear better than original.
Scott06
Nice fix will be interested to see how it holds up.
