Outboard will only start when given 10%-30% throttle. Will not start when given full throttle or half throttle.
jimmbo
Why in the world would you want to start an Engine at or near WOT?, Next you will be asking why a lot of Outboards can't be started in Gear
909
I would imagine so. Fuel pump and reed valves are the only things I haven't touched yet.
909
Out of frustration. Hard starter.
jimmbo
If an engine is Flooded, then setting the Throttle to WOT and opening the Choke is a way to potentially clear the excess Fuel, but so does going for a 15 minute walk and contemplating the Horizon.
If you guess it is lean , then clean the carburetor or make the adjustments !!!
909
I've cleaned the carb 3 times.
Same carb works fine on another motor.
Every thing you did , and mention points to and indicates that something is wrong with the metal bits inside the motor.-----Up to you to open a tool box and figure it out !
I am stepping aside on this one.----I fear when 909 finds the issue we will see a post saying---" how come none of you experts knew that "
909
Exactly Racerone. "How come none of you experts know what's wrong with my motor."
Just kidding. I'll buy the winner a beer .
The truth is, some new user in the future is going to read through these posts and it will benefit them. If this problem ever gets solved.
Crosbyman
ok so electrical all ok, compression ok carbs ok throttle plate ok link sync ok yet fuel does not reach it's destination to start the engine ...
any chance the crankcase case vacum needed to "pull in" the fuel is low compared to your "5 other working motors". It is a bit ackward to measure it but can you at least to a comparisson
you did not skip a tooth or two on the thotlle handle did you ? what is the mdl # ???
  • Like
Reactions: 909
909
you did not skip a tooth or tow on the thotlle handle did you ?
The throttle is cable driven. Crankcase leak is very possible. Thanks
Crosbyman
yep...later models are cable but did not have your mdl ...same issue anything changed on the cable linkage...something misadjusted
909
Yes. E10RECC
Reminds me of a woman. Nothing but headaches
909
The motor does what it's supposed to do and behaves.
A woman can too if she doesn't leave the kitchen.
909
Yes . Hard to diagnose. Still gave great compression.
