1975 23 foot fiberglass with cuddy
Jakem
Ensign
I am wondering about prop size for my old boat. It had a 21p when I bought it. I switched it to a 19. It's been suggested I run a 16 or 15. Does that sound right. Boat revs out at about 3500 ram for causing speed wich seams high to me
What boat ?----What engine ?----And what condition is the motor in ?-----If motor is sick then changing props means nothing !
Jakem
Ensign
It's a campion boat with a ford 302...the engine is being worked on timing wise but ran strong before.
If I recall from your other posts, your down slightly on compression
Ayuh,..... You need whatever prop pitch that allows the motor to run at 4400/ 4800 rpms, at Wot, trimmed, with yer average load of fuel, 'n gear aboard,.....
QBhoy
Get the timing sorted and take it from there. Once that’s sorted, tell us what outdrive she is abs her ratio of you know. But as she is…you’re about 2000 rpm low at least.
