Timing info 1996 Johnson 130hp
goatbreath
Would appreciate timing degrees for j130tleda WOT and idle. Bought online manual but can't find them. Sorry manual. Thanks
Need to ask.----What is your motor doing / not doing ?-----Timing on these motors does not go out of adjustment.-----If there is an issue what trouble shooting has been done ?
goatbreath
It won't idle properly. Spits misses. Over half throttle good. It has been to 2 supposidly good shops. They messed it up. Adjustment tip was off idle lever. lever is adjusted all the way out and I would like to try Joe Reeves method of WOT timing check. Can't find WOT timing degree. Thanks
goatbreath
I have cleaned all carbs. New plugs. Adjusted idle screws from 4.5 turns out to 7 turns out and everything in between. Ran with auxillery fuel supply. Still not right.
Post compression numbers.----Running with VRO in service or 50:1 mix ?
goatbreath
All cyl 110 to 120 psi. VRO operates well. Old engine but very low hours and well taken care of. We don't have many boat engine mechanics here. I have some 2 stroke motor bike experience and a little boat motor experience.
goatbreath
Thanks for taking the time to reply.
goatbreath
Thanks for timing info. Just want to see if “mechanics” messed with timing. When I advanced timing lever (counter clock) idle got better but I ran out of threads. Also do you know normal turns out for carb idle air adjust screws?
