goatbreath
Thread starter- Joined
- Nov 16, 2021
- 6
Would appreciate timing degrees for j130tleda WOT and idle. Bought online manual but can't find them. Sorry manual. Thanks
It won't idle properly. Spits misses. Over half throttle good. It has been to 2 supposidly good shops. They messed it up. Adjustment tip was off idle lever. lever is adjusted all the way out and I would like to try Joe Reeves method of WOT timing check. Can't find WOT timing degree. ThanksNeed to ask.----What is your motor doing / not doing ?-----Timing on these motors does not go out of adjustment.-----If there is an issue what trouble shooting has been done ?
I have cleaned all carbs. New plugs. Adjusted idle screws from 4.5 turns out to 7 turns out and everything in between. Ran with auxillery fuel supply. Still not right.It won't idle properly. Spits misses. Over half throttle good. It has been to 2 supposidly good shops. They messed it up. Adjustment tip was off idle lever. lever is adjusted all the way out and I would like to try Joe Reeves method of WOT timing check. Can't find WOT timing degree. Thanks
All cyl 110 to 120 psi. VRO operates well. Old engine but very low hours and well taken care of. We don't have many boat engine mechanics here. I have some 2 stroke motor bike experience and a little boat motor experience.Post compression numbers.----Running with VRO in service or 50:1 mix ?
Thanks for taking the time to reply.All cyl 110 to 120 psi. VRO operates well. Old engine but very low hours and well taken care of. We don't have many boat engine mechanics here. I have some 2 stroke motor bike experience and a little boat motor experience.
