Franco_boater
- Nov 2, 2021
- 137
Ciao from Italy my friends ,
we have found water leak in my bellows, mechanic changed my bellows, gimball and now I need to change shift shaft seal bushing.
My question is: to remove and install the bushing back to the housing, do I have to press it in in which direction? From below to the top or top to down? Is it the difference?
Also the seals, should the spring be faced upward for both?
Also, for the upper bushing + seals, is it better to install bushing then seals? or seals then bushing?
Thank you for all your help
ciao!
ciao!
