Counter Rotating vs Non-Counter Rotating Twins
FreeBeeTony
How much difference in performance could I expect from the subject?
I currently have counter rotating twin outboards and have somewhat "mastered" backing into my slip.
If I was to replace them w/ a pair non-counter rotating twins, how much different would the handling be?
dingbat
Depends on the hull and past experience.
Counters zero out prop torque. Stops the roll, reduces steering effort and makes it easy to move bow left and right. Makes a big difference in a hull with a lot of deadrise.
One of those things “if you didn’t know any better”. Not a compromise I would make.
FreeBeeTony
My boat is in my signature: '95 Grady White Islander.
you are really trying to talk yourself into twin single props arent you?
FreeBeeTony
no, I never operated a boat with twin engine non counter rotating props. not sure how drastic a difference it would be and was wondering if trim tabs would negate the issue
trim tabs will not help when docking
you will loose fine control when docking, however it would be manageable
think of it this way, single props are like running summer tires on snow covered ice.
duo props are like running studded snow tires
Why are you talking about " single props " verses " duo props " on this topic?-----I had no trouble running twin engines ( right hand rotation ) and have never had a counter rotating set-up.----And I would not want one either !!
FreeBeeTony
I never mentioned duo props.....twin outboards.....not duo props.
