Need help with my 3.7l mcm 180
So if I put an external alternator on it does it mean that I won’t need the regulator anymore?? And if so can you send me a wiring diagram thanks
The kit you buy will have instructions and schematics
The Begginer
So split the drive in half and as I predicted the top was seized tried to remove the top cap but 2 out of 4 bolts were seized what to do now ??
Ayuh,.... Find a good drive with the same ratio,....
The Begginer
So found this pic of a 470 on the internet, question what’s this ??
The Begginer
buy a new SEI drive
Can’t I live in the Philippines any other way ?? Maybe change the seals or bearings the unevirsal joints are smooth like butter and the shaft is peachy the lowers also peachy I think it’s this part I circled by black ok I circled by blue I think is bad not all but maybe some
They ship stuff international all the time
nola mike
Shipping and import is like $400
Yes, boats are expensive. No cheap fix. Your options are: 1. find a used one 2. Buy a new one 3. Find the parts and someone with the knowledge to fix it, 4. Buy some paddles and turn it into a row boat
The Begginer
I think 3 is gonna be my choice plus I think it’s cheaper oh and btw what are the reasons why my drive got seized cus they said they ran it 1 a month so like this month they ran it the next month the drive got seized then they left it for 5 years so what is the main reason for the drive seizing up ??
The Begginer
Oh and how much would a used alpha 1 gen 2 lower sell for ?? Planning to sell my lower if worst comes to worst
The Begginer
Oh and lastly to inform my boat is actually a glasstron v-174 1976 bayflite and yes the merc 470 ain’t the original engine it’s been swapped
The Begginer
Ohh and here’s another question, they said that when it was new it had the fuel tank under the bow cus it is a closed bow but I’m thinking maybe I can open the bow and fit a fuel tank under the floor at least a 30gallon tank is that even possible ??? And can I raise the sides of my boat and the transom to be taller than the engine so i can make one of these flat apholstered engine covers ??? And if so how ?? Thanks for the help
