Transducer question
Newtotoons
Bought new Garmin 73sv fish finder that works amazing but the transducer is very vulnerable. I have a 16' pontoon and the transducer sits right on the bottom when pulled up to shore. Is there a stable way to a swing the unit up so it is out of harms way?
Buddy mounts his transducer on a telescopic pole he can retract
Made himself. Two pieces of aluminum tube, some aluminum plate and some time in the shop
Newtotoons
Sounds good if I can reproduce it. I'm a woodworker but don't have much experience with metals.
Grub54891
make one out of wood dowels, closet sized or maby a bit smaller. When you get the setup you like, duplicate it in metal.
my bud used a 1.5 x 1.5 aluminum tube with 3/16 wall and a 1 x 1 aluminum tube with 3/16 wall.
the outer tube had a mounting flange welded to it so he could bolt to the aft fence
the inner tube had the transducer mounting plate welded to it, and a stop at the top.
the inner tube had a hole drilled thru near the top
there were 2 holes drilled in the inner tube (two different heights) and he used a small quick pin to keep in place in the water or raise up as needed.
since then he welded a mounting bracket behind one of the tubes
roscoe
Use these for ideas to fabricate.
Newtotoons
Sorry for not getting to this sooner, but I checked out your links and think I found a viable solution there. I just don't have the time right now to build something myself. So i think I might have to try something that someone else put their time into. But thank you to all of you who replied.
