Hull liner
JOFO17
I need to replace my hull liner and am looking for some input in chosing a fabric. I have seen prices ranging from about $7.00 per 6' section up to Hull Blanket at over $20 for the same length. Has anyone used Ozite hull liner? It looks similar to the expensive stuff but there aren't very many reviews.
JOFO17
Ayuh,..... What's a hull liner,..??
It is like a head liner except for the hull. A carpet like material that insulates for sound and temp and makes the cabin look pretty.
Go to any RV supply. Like Panther RV
Its $6.55/ ft
Same crap other places charge more for
Panther also has wider than the 72"
JOFO17
Its $6.55/ ft
That's exactly what I was looking at. Have you used it before?
JOFO17
I ordered my carpet and the recommended adhesive a couple weeks ago and I am all set to start. Except for 1 thing. Can I use acetone or another solvent to wipe off any adhesive residue? The 3M GP adhesive cleaner was a bit pricey.
AShipShow
Start with acetone or googone, if they don't work, then use MEK... don't mess around with MEK though.. Suit up in all the required PPE.. That stuff is nasty.
