Why my leaf springs are sliding?
Wave34
Dual axle trailer,
only at one wheel, the bottom leaf springs moves sideways.
I suppose it is due to the side force applied to the axle when turning tight corners, but I don't like that.
How to secure this?
Wave34
No keepers, I bought the trailer new (has been fabricated for my boat).
Can this be added after or it is riveted to the leaf?
Ok, I will look at my signature picture...LOL... not my Chaparral Signature, but the signature of my post.
Ok, not funny, I had to say it... ok, going to bed. zzzz
dingbat
I don’t have keepers on mine either.
The whole spring is sprung. Hold down clamps have shifted as well.
Guessing one of two scenarios:
1. One or both of the lower springs have broken.
2. The clamp was not torqued to specification and shifted
Replaced my springs as PM two years ago. Had a broken leaf in two out of four spring packs. Looked perfectly fine until I removed the clamps and the offending leafs fell on the ground. No idea how long they had been broken.
I suggest taking the load off the spring and inspect
dingbat
Wave34
Thanks everyone.
I now know what those metal straps do in a leaf pack.
I found some online. But they look a bit flimsy like for a small utility trailer.
I will keep searching.
full
robert graham
Maybe some 2 inch by 4 inch steel bars, bent in a vice with some heat to form the "C" shape required....
Wave34
Maybe you should remove the spring and see if the center bolt is intact before doing anything else?
I put my finger under the support and I felt the head of the bolt, so it should be fine. Also, they rotate but stay centered.
Bt Doctur
Your spring package is not correctly located in the axel perch and the U bolts are not straight either implying the axel length is incorrect for the springs package.
Plus putting the brake wiring in the axel is really a stupid idea. Allows water to enter and rust from the inside out
Wave34
click to enlarge
Yes, I saw that. It is like if the axle moved sideways or the U bolts are not tight enough.
This is a trailer I had built for my boat in 2018. I had to call the guy 3 times to fix things, and the rest I fixed myself. So, another thing to fix myself.
