StuartAdair
Thread starter- Joined
- Oct 11, 2019
- 6
Hi,
Sorry for resurrecting an old post but its very relevant to an issue I have on a 5.7 Mercrusier, Alpha 1 outdrive. Ran it all last year and the temperature gauge rarely moved over 100°, so much so that I always thought that it was broken. Had the boat out this winter and put in a new water pump and water pipe leading to the transom as a service item. With the boat back in the water now its running at 140° at 1400 rpm but as soon as I drop to idle the temperature goes way up. I initially thought I'd made a mess of the water pump change but there seems to be good flow of water. Please check the video which is the engine at 700 rpm idle speed. https://www.youtube.com/watch?v=MkDbXCcvL98
I then checked the thermostat which looks like the attached pic and has seen better days.
I've ordered a new stat and circulation pump as I suspect both are original 30 year old items.
What do you think about the water flow video? Does it look about right for the engine at idle ?
Many thanks
Stu
Many thanks
Stu
