‘74 Holiday restoration
Kmsp1264
Yes, I’m happy with it, easy.
that’s the first mate, she’s learning
Kmsp1264
963F2B19-433E-429B-9D96-F9FCC27EE2B1.jpeg wiring/controls
Watermann
Looking good, :thumb:
Thinking maybe I would have put the boat back on the trailer before installing that cast iron lump in there.
Kmsp1264
Kmsp1264
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Nice looking trailer. Paint and everything looks to be in good shape. I am guessing paint and such was already done?
SHSU
Kmsp1264
Kmsp1264
Kmsp1264
Kmsp1264
25359457-A27A-41FB-8F2E-502C9207D883.jpeg That wasn’t too bad getting it on there. The next one is with out engine
outdrive and engine run soon.
SHSU
Did you add any bucks or is it only on those 4 rollers?
Paint job still looks good!
SHSU
Kmsp1264
No bunks just rollers, one missing, need to come up with a wobble roller up front
SHSU
How many rollers do you have currently? It doesn't look like you have enough to properly support the boat.
Just my 2 cents
SHSU
Watermann
Just my 2 cents
SHSU
Yeah I agree with the rollers not being enough to keep from deforming the hull, it'll be a real issue with a heavy 600# iron block too.
Kmsp1264
Yes, thanks, might do bunks.
outdrive complete and a starter swap, slow but sure. A09EC58E-2B2E-4E42-AAA6-88D0287135C3.jpeg
Kmsp1264
BA1BB459-EA5F-4ECF-833A-0685757F7820.jpeg Yes, thanks, might do bunks.
Kmsp1264
4 bunk brackets, 2per side, 2x4’s and carpet should do it
SHSU
Good plan. Make sure NOT to use pressure treated 2x4s, the copper sulfate will cause corrosion over time.
SHSU
Watermann
Or if 2x4s seem a bit weak, you can go full on monster bunk like I did for my galvanized trailer.
y4mld5XbKidcdi1qPW-r8ql_LCfBWlBW7yxN5Bc0TA9AcGzMVHzZwK89MRUdIStRX6mA4u0cygKoq-gX5WEyg_UgKfFsR7IPKAnUweQ6F71uxFUo67LIIC7RkzwuzgnhORGg2ixXHcVpG9pf5DmcziNmWDuCfuRP3WtG23xXHqu0S60vQ7GOLYhdik4nJRoPFyS-jQstgreCiB4cH-Feih1Cw
Kmsp1264
