alipinski397
Thread starter- Joined
- Sep 3, 2013
- 63
So anyone that followed Jason's most recent update on his thread for the 22 Islander build, you now know it found a new home with me.
Given the epic build thread and history on it I felt i needed to start a new thread continuing the legacy.
I think a little back story on how I ended up with it is in order. I had a Mariner 220V I had started a rebuild on this spring and a couple months ago had finished gutting it and got the old foam removed. That's when i found some pretty severe corrosion. Its past life was in a salt water area and i knew there could be some corrosion to fix but it was bad, really bad.
So i started searching for solutions or replacement hulls and stumbled on Jason's Islander thread. I had been considering islander hull for a replacement and cutting the top off to have the open bow center console setup of a Mariner. I realized he was local and only 25 min away, so I sent Jason a message to pick his brain on the process Not knowing if I would even get a reply as he hadn't been active on the forum for quite a while. A few days later he got back to me and low and behold he offered the islander for sale. He had back in the garage and somewhat tore back apart getting ready to convert it to an outboard. He had some other things on his plate and it had been sitting for a while collecting dust and he was ready to part with it. We made a deal and I drug it home.
My plans for the boat:
Will post some photos in the replies as the thread progresses, need a few more posts in order to attach photos.
- Finish the outboard conversion
- Convert the dual console to center console
- Plan to keep the bow storage and front seating structure as is
- Add a T-top
- Add a bow mount trolling motor
