The iboats gearhead channel
sam60
I like that BWR...2 stroke?
sam60
If we all just had unlimited time and money...
sam60
Something is wrong. It was easy with the same steps weds.
Here are a few - Me in a cart.... and sliding off track to hit the only embeded rock in the grass to shatter the chain
Gratuitous pic of a bar stool racer
lost the hard drive with the pics of most of my past hot rods, however these were taken by a friend and dug out of emails
My 1940 Chev Deluxe(s) shortly after getting them home
test fitting the Cummins Diesel in the 1953
the most fun you can have with 4hp
The motor refresh for the Rogue
avenger79
brought this one home last summer..long way to go.
avenger79
couple other garage residents
sam60
454 .030" over that I pulled and put back in boat. Car I own for 2-3 months and put 1/2 mile on it. Click image for larger version  Name:	454 010.JPG Views:	1 Size:	602.1 KB ID:	10691353Click image for larger version  Name:	12-9-17 a.jpg Views:	1 Size:	95.5 KB ID:	10691354
sam60
That Cummins V-Drive causes a small tingle...getting old. :lol:
I know the limit of the Cummins V-engines is about 3500HP in a pull truck. you cant get any more fuel to the injectors because there is not enough meat in the head to drill the fuel passages any more.
sam60
This will be the toughest crank I've had to spin in a long time. Need to build strength and endurance so I can get back to work. Cheap used get out and exercise unit.IMG_4619[1].JPG
