Boomyal
Thread starter- Joined
- Aug 16, 2003
- 12,072
Well I continued to have problems with my epoxy resin, annoyingly bubbling up. I had been applying it with a roller, from Home Depot, specifically for Epoxies. Of course every time it cured, I'd have pits in the epoxy after sanding off the bubbles.<br /><br />I just put a final coat on my motor mount stringers and it was bubbling up again. I got the bright idea to try tipping the resin with a brush. Low and behold, it wiped out the bubbles, they did not reappear and the resin flowed out nicely.<br /><br />I don't know whether there was a reaction with the roller or just a physical interaction causing the bubbles. The roller is definitely a good way to spread the resin, especially on vertical surfaces. So the moral is, just TIP it when you are done.
