2012 Lund WC-14 transom support crack, how to fix?
Status
Not open for further replies.
FireFire
Hi,
Just came back from fishing and I found the crack on the support bracket. I guess I was fooled by Lund saying they don't need transom saver and I always put my 9.9 at the back.... Lesson has been learned...
But any idea if Lund will warranty this issue? or I have to find the way to fix it?
Thanks
call lund, however most likely your out of warranty anyway.
if so, get it welded.
FireFire
Thank you Scott. Do you recommend to take the bracket out and get welded and put back in? Looks like I need to get rivet out as well. My first boat and my first repair....
Take whole boat to welder, go fising 10 minutes later. If you dont know of a welder, stop by your local radiator repair shop. Most of them weld aluminium every day
Watermann
The terminology for that is a "knee brace" and most guys repair them by removing the broken piece and replacing it with a piece of 1/8" angle by bolting all the way through. That will crack through the weld on one side and the heat won't be good for your riveted seam right there.
I also wonder why it failed. What size motor do you have and do you use a motor toter when trailering? Some reason the transom is being pulled away from the brace, you can see the gap.
fetch
sunwalks
I have the same problem but at the top of the bracket on my 2009 lund wc 14 . How did you repair yours and were you happy with the result.
GA_Boater
This thread is outside our 90 day inactivity limit. Start a new thread. Most cracked knee braces are the result of rotted transom plywood, so investigate more.
Closed.
Status
