First attempt to add a link...sorry to be such a newbie...bare with me please...any and all info would be greatly appreciated.
Yep, I see the pic as well. Looks like quite a project there. As GG mentioned, I would defiantly take the time to research and understand what you are about ready to get into. Not trying to scare you but want to make sure you fully fathom the amount of time and money it appears it will take to make her something you will have years of enjoyment on.
From what I see:
Trailer will require attention. How did you get it there? I don't see any tires. Looks like fire damage at the rear, am I seeing that right? Would need a complete blasting and rebuild or new trailer
Motor looks to be a Mercury Tower of power. You would need to get it off, make sure you have good compression, replace all your seals, impeller, spark plugs, redo carb, and check the tilt and trim.
Boat should be properly stripped of everything, even taking the cap off to do it right. Take out all the old stringers and transom (I can't see any of that still being in good shape with what I am seeing). Then properly putting it back together.
Once done, you will have a better boat then when it came out of the factory.
With that quick snip it, I will say that if you are willing to put in the time, money, and energy you have definitely found a place where there is plenty of knowledge to offer and help you along.
I have attached two links, one being to Woodonglass' thread how to fiberglass and to another member that did a similar project to you.
Woodonglass:
http://forums.iboats.com/forum/boat...1961-lonestar-flamingo-splashed-w-pics/page42
Project Glastron (Can't find his thread, but here is his videos)
https://www.youtube.com/watch?v=ldow-POe97A&list=PL3VcOAbbi5n1gEzUaZF3CiTJs4-21ol2d
