- Mar 8, 2009
- 43,599
The part number is A1103, just search for it.
I cleaned the hole out with a 1/2 drill bit (hole is a bit larger) then used my pocket knife. Using some acetone to finish the outside clean up. Want to get it all off the gel, but leaving a tad in the hole should not be an issue. I'll squeeze some in the hole once its close and fill it in
