Scarfing stringers
demarko210
I have been reading about doing different types of joints. Scarf joint has been the popular way of attaching new stringer wood to old. Everything that I am reading about doing joint on my stringers say when placing the joints together glue them with epoxy.
My question is can I use thicken ploy to glue the joints?
Can I use a double lap joint (B)?
https://drive.google.com/file/d/0B95...ew?usp=sharing
JASinIL2006
If it were me, I'd use epoxy but I'd also run some mechanical fasteners through all three boards, as well. I'd use either screws (going in from both sides) or a through-bolt. That will be substantially stronger than epoxy alone.
gm280
demarko210, many many iboaters have used polyester resin to make their stringers, transoms and floor glue up's without any problems what so ever. And you can add in some Cabosil (fumed Silica) to thicken the poly to the consistency you like or need as well. So if you want to use polyester, go for it. It will work without any problems.
I suggest you read a few boat refurbishings on these forums to see what's involved before doing anything as far as replacing stringers and such. So many great ideas and options to see and read about. JMHO
kcassells
old news here. Go to his forum. Demark keep your questions in your forum. Easier to control. GM is right on the money.
demarko210
Thanks KC I thought it would have been new topic. JAS and GM thanks for the input
