chevymaher
- Mar 29, 2017
- 2,938
No Title
Okay clearly the switch had the thermal protection in it. It doesn't shut off when it gets to hot anymore. Turns right on and off now. And it gets so hot you can't hold it when your beating on it now. So I guess just let it rest once it gets warm. Good ol new grinder. I am beating it to death. Just make it till the end of this I will get another one for regular use. It is pretty handy.
Okay I did get pics for today. I am concentrating on the huge blobs of mess they left first. I got a before pic of the starboard side as a comparison for the port side i worked on. Port stringer had the blob of fiberglass and it was 8 inches long and at least 5 inches deep around where the stringer was. With alot of dry chopped strand sticking out the sides of it.
Progress is slow but sure here. I am seeing the light tho.
I got yard work to do tomorrow. Hate that. Not really but it does take away from boat work. I got to weed again and trim cut the grass and gardens. Flowers and vegetables are nice but alot of work to. It rained 2 days straight so the grass is going wild again. And the silly weeds are popping up.
And in the fyi dept. The goggles if you are silly enough to use your shirt which is covered in fiberglass dust to clean them. Wow it scratches the snot out of the inside of them. But the rubbing compound and buffer cloth fixed that. So running water take a break and wash up before doing that. Hypothetically of course I wouldn't be stupid enough to do that NOT.
