BWR1953
- Jan 23, 2009
- 6,545
Hiya ybstuk! :wave:
I've been following along with your project and WM definitely has given you some excellent advice, as he usually does!
One other thing that I might add is that you should re-buck the rivets around that keel seam if they're not absolutely tight. Get 'em locked down after cleanup, then apply the Gluvit on the inside of the hull.
Many of us have used Gluvit, myself included and it works very well. On my Kingfisher I was able to tilt the hull nearly vertical on each side when applying the Gluvit, letting it seep deeply into the nooks and crannies. Did the same thing at the keel by raising the stern of the boat, then finally did the same with the bow. When it was all done, the boat ended up being bone dry in use. Been that way nearly 2 years now.
Keep up the good work! :encouragement:
