Starcraft islander resto..... where to stop
Watermann
or replace rivets if the stringers are riveted to the tops of the ribs by blinds and are not tight.
Captaincrisp
Thx guys boom instant responses!
Looks like somebody needs to do a transom.
So excited....
So when can i get a rebuild thread, or is my gramar to poor lol
jbcurt00
IMO, just carry on here w the rebuild
If you prefer you can start a new rebuild topic any time ya want.
Captaincrisp
Its fine i really dont care. I just thought it was funny because this started as a rough up gluvit and throw in a hand full of pop rivets re gluvit and paint then go float around. Now its a complete re do
jbcurt00
Up to you.
If you'd like a title change, any Mod can do that too. Just post whatever you'd like it changed to.
GA_Boater
That's the way it goes. A couple of rivets here and a little sealer there and there next thing ya know, the boat id scattered all over in pieces. LOL
Like JB said - If you want a title change, just put the new title in here or PM one of us. Might even speel things right. :D
Captaincrisp
So transom says its rated to 240 hp on plate starcraft put on. when i bought it came with paper work from transport canada small vessel compliance program. (Svcp) non pleasure craft . It reads 250hp. Id like to be able to put a simaler weight 300 hp motor on it . Now that im doing the transom is there a way i can beef it up and make sure its safe. I guess its a old beat up water taxi. one guy i saw at the marina remembered it from when he used to log on north vancover island as there water taxi.
laurentide
300 HP? That's 600 pounds of outboard on a 1700 pound boat and way more power than you can practically use in my opinion. I think you'd have trim issues at low speed. A 175-225 would be more than enough. These boats are light. Even a 150 would be fine.
I just did a google image search for "Starcraft Islander 221 outboard" and almost all of them have single 150's.
Watermann
To safely up the rating you would need a longer, deeper and wider boat. OB's are way different that IOs the way the HP is applied to the boat and the effect that the weight has being on the outside hanging out the back rather than inside resting on the hull. I would say 200 HP is more than enough.
Captaincrisp
Dose anyone know the size of rivets i need for the hull and best type.
Watermann
If you're wanting to use solid rivets then you'll need
Brazier head
3/16" diameter
3/8' length for 2 layers and 7/16' for 3 layers
2117T4 alloy
I get mine at the link below but shipping is killer so make an order for all the rivets including blinds you'll need for the decking and other jobs.
http://rivetsonline.com/solid-alumin...2-to-3-16.html
Of course you'll need a 3/16" brazier head rivet set, air hammer and compressor. If setting the rivets below the waterline I recommend using 5200 to seal them.
Captaincrisp
Ahhh i cant find my dang img code when im on my cell phone on photo bucket app anyways pic above is of some really nasty corrosion spot i found that is actually though the hull some other bad spots but nothing close to this one ughhhhh hope this hull is worth saving
Watermann
Clean the area up and post the pic again from both sides.
