Transom replacement time.
CrashBob
I had hoped to put this project off till the end of season. After finding my boat half sunk after only a few hours tied to the dock, its time now. The boat is a 16' 1978 Starcraft Tristar. I have been lurking this forum for ideas and procedures to split the cap from the hull. I would appreciate any tips, how-to info with regards to this type of repair. I am experienced with fiberglass and am an accomplished carpenter/furniture maker. However, I have zero experience with fiberglass boats. My last boat was an aluminum Sylvan upon which I successfully replaced the transom.
Thanks in advance,
CrashBob
Post pics, we can help. Read the DIY links in the stickies
gm280
Yes pictures convey so much more then paragraphs of text can most of the time. So post away.
Woodonglass
Inboard or outboard? You have 3 options. 1.) Pop the Cap 2.) cut the cap at the gunwales just in front of the splashwell, 3.) Cut the rear skin away to gain access to the wood core. (NOT recommended) Boats of this vintage usually have deck, stringer, and motor mount issues too! I'd be prepared for a full gut job and restoration. We're here for you when you need us. Get some pics posted so we can see what you're up against.
slimdaddy45
I just did my old 74 Sea Sprite tri-haul and I didnt split it I just cut the sides up past the splashwell I didnt have to do the floor or stringers just the transom so I replaced the wood a glassed it all back and glassed the sides back up turned out pretty good I havent painted or finished out the sides yet it worked out ok sure saved alot of work its an old boat that I just use for fishing I didnt worry about the looks as much as it being safe I used close to 3 gal of resin and almost 4 yrds of 1708 and 3 yrds of 1.5 oz csm I probably went overboard on covering the wood but it is sealed up good and stronger than it was before since its only a 1'' transom it was easy to do just nasty from the grinding to clean it all up
CrashBob
It is an outboard. Tell me more about option #2, not sure what the gunwales are though. An illustration showing the cuts would be extremely helpful, CAD or crude, just need an image.
CrashBob
Great! Now I have an idea of what options I have to do the deed. You guys are a huge help. I'm about a week out before I can get started so when I do, I will be posting pix with the gruesome details, stay tuned!
