interalian
- Jul 23, 2009
- 2,105
I'm going to say something looks out of whack with that throttle arm. It's leaned way to the rear of the motor, and the link to the throttle cam appears to be adjusted way forward. Seems as though flywheel alignment is off. If you're having trouble getting the nut loose, just do the TDC check. Take #1 plug out (highest plug on motor). Put a long screwdriver straight into the plug hole and rotate the motor until the screwdriver is out as far as possible. Look at the pointer and see where it aligns on the flywheel.
Oh, and I don't think that's the right rectifier for your motor if the two lugs don't span the two mounting points. Note that the two bolts to secure it are different sizes. If loose, your charging system won't work properly.
This is how my '82 90 looked before I took it apart. Note the throttle arm is pretty much vetical and the nylon adjuster for the cam link is threaded much closer to the throttle arm. Now I'm not saying it's wrong necessarily, but it looks really really odd.
