Steering help! New boat owner
Erwin4200
Hi all, have a 2006 mercruiser 3.0L with 2006 alpha one drive on 2006 bayliner 185. I've only had it out twice since buying it and it's my first boat. Turning the wheel is very difficult when in the water but turning wheel out of water is no problem.
First off, am I right in assuming this is a power steering engine? I've looked a lot online about removing steering cable but when I looked at the alpha one I didn't see a steering cable like I saw on some videos so I'm guessing I don't have manual steering?
It shouldn't be so difficult to turn the wheel in the water. Previous owner said they had it serviced annually.
Where can I start to try and diagnose the issue? Basic language, explanation and pictures would help so I can locate what people are referring to iif possible. Trying to learn as I go so I can work on the boat on my own!!
eavega
I'm guessing pictures would help. I don't think they typically install power steering with the 3.0L, especially bayliner. I could be wrong.
-E
Bt Doctur
Guessing it makes easy left turns and 2 handed right turns
stonyloam
Look at the front of the motor. If there is a belt driven power steering pump, then you have PS, not, then you don't.
Rick Stephens
Boats use the same power steering pump as cars and pickups. If you have a pump, you have power steering. Your description makes me think you do have power steering and it isn't working right.
Behind the motor is where the steering cable comes to the transom plate and steers the boat. If you have power steering there is a control valve with a booster there. Looks something like this:
Erwin4200
what kind of files do pictures have to be? i've tried uploading jpg and jpeg and it won't allow me to do so
Erwin4200
i haven't noticed a difference turning one direction from the other. i can't remember off hand if it's easier at midspeed rather than full speed
Erwin4200
right now these are the only pic I have of the engines, have another on phone but keeps telling me it's corrupted. Will hopefully be able to get more tomorrow and if not tomorrow then the 4th for sure
Rick Stephens
Do you see any hydraulic pump on front of engine?
Any booster/control valve behind engine on driver side?
thumpar
Take a picture of where the belt/belts go. If you have power steering it will be driven off the crank with a belt.
Erwin4200
20160702_164750.jpg 20160702_164935.jpg 20160702_164828.jpg 20160702_164816.jpg 20160702_164846.jpg 20160702_164728.jpg 20160702_165500.jpg 20160702_165025.jpg 20160702_165242.jpg 20160702_165515.jpg Here are a bunch of pictures. Looks like it's power steering. I couldn't find the dipstick to check the levels though. Found engine oil, engine coolant and drive oil but not the power steering fluid. Thoughts? That's the first place I'll check and if that's fine then what is the next step.
thumpar
That isn't power steering. The pump you have a picture of and rams are for the tilt/trim. The power steering pump would be mounted to the engine and have a belt running it.
Rick Stephens
Manual steering.
You might start looking for something that is loose or worn out. Grab the outdrive and with someone else holding the steering wheel from turning, try pushing, pulling, lifting, twisting and basically shaking the outdrive to see if one of the swivel pin/bearings is worn out or sheared off. Same inside the boat, grab ahold of the steering cable end and give it a shake.
Erwin4200
Ok so now that we know its manual steering is this the steering cable then here?
Rick Stephens
Yes Indeedy. The big aluminum nut at the left, nearest the black cable housing, is what attaches cable housing to transom. Then at the steering arm at the right end is a cotter key and Clevis pin that holds the inner steering cable end on. Pull the Clevis, loosen that nut and the entire steering cable will pull loose of the tube.
Don't loosen the big nut at the pivot. PITA to reset it correctly.
Erwin4200
Manual steering.
I'll start with steering cable but wouldn't I have issues turning the wheel out of water if the cable was the problem? What about grease zerks?
Erwin4200
Where are the service manuals for engine and drive on here? I went to adult only section but they only have service manuals 1-4 there which look like they only go through 1984.
