I have recently done shift, u-joint and exhaust bellows, and I know these are all well sealed. Still seeing a small trickle of water getting in somewhere around the transom. Is there anywhere else that it could be coming from that I missed?
If your transom is sound, and not rotten, then a common area is the seal at the bottom where the hydraulic lines go to the the trim. But unfortunately a more common area is the seal around the transom assembly itself - which almost always signals a soft transom.
Wow, I never heard of that one leaking before, maybe thats my issue. Also, looks like an easy change out without having to dump all the trim fluid.the connector block uses a gasket between it and the housing![]()
depending on the work performed a drip above the water inlet is usually the frim wire bushing or they only put in the bottom bolt and skipped the top one.
Thoses plugs are evidence the upper seal/steering pin/ yoke have been repaired/replaced. Do a search for "installing the missing mercruiser grease ftting"
It will help prevent that repair in the future
How hard is it to remove that steering part?
