Chrisravosa36
- Aug 16, 2015
- 622
It will work with Teleflex push-pull steering, but not well. You heard right, turning radius will be compromised, and you probably will experience a problem with full tilting without obstruction, which could bend or break something if you hit an underwater obstruction at speed.
I took a second look at the picture and that blocked-off hose is supposed to go the the vacuum cut-off switch. And I don't see the switch. Somebody apparently removed it.
Also, it appears the ring is not a separate piece on that flywheel, so you will need to find a different flywheel if you intend to put electric start on it. Might be tough to find one for that year.
How much % would the turning radius be compermised? Will it take over 40% of turning? What is the other alternitive to get good steering? Also what does the Comercial with Interlock mean? Interlock? Cant seem to find a parts diagram for this motor.
