Chrisravosa36
Thread starter- Joined
- Aug 16, 2015
- 622
13'6" Runabout 50hp Overpower?
Hi, Im planning on putting the 1974 johnson 50hp on the back of the 73' MFG Carefree. Its legal in my state, but I want to make sure its safe. Its rated max.30hp. The years before this were all rated for 40hp, but when MFG sold its company over to cresiliner, they wanted to make it down to 30hp. It is the same hull, same format. THe only diffrent things about it are the decals and pin stripes. I was planning on putting a 40hp on it, but I got this Johnson for next to nothing, and wanted to try it out. Anyways Il have quite a bit of gear on the boat to add some weight, max weight is 900 something, cant quite read the label, but it starts with a 9.
Myself - 160lbs
Motor - 187lbs
Marine Deep Cycle - 70lbs
Starting Battey - 40lbs
Seats - 15lbs
Gas 6 Gallons + Tank (Plastic) -40lbs
Safety Gear - 20lbs
Fishing Rods/Bait - 30lbs
Trolling Motor - 27lbs
All Wiring, Lights and accessories - 20lbs
Carpet - 8lbs
Steering system - 15lbs
Throttle - 5lbs
Ignition Switch + Wiring - 2lbs
TOTAL WIGHT IN BOAT = 639LBS
So I still have plenty of weight for one more adult.
My idea is to keep the batteries in the front, and gas in the back. This should help balance the boat better, any input on this? Ofcourse I will have to test it to ind out the best solution. I will definitely be using a 4 bladed propeller, I hear it is better for turns and just handling in general. Anyways, the motor is older, I hear that they use to measure them at the powerhead for 50hp back then, so by the time the power got to the water, it was around 45 - 48hp. I am working on the transom, it will defiantly be strong enough, as it will be seacasted. I would have got a 40hp, but I really want to try out this motor, my orignial plan was a 40hp, but I got the Johnson seized up for 50$, and am fixing her up, so if it doesn't work out with the 50hp or its just to dangerous, I will just buy a 50hp. Safety is KEY! All imput is valued greatly, I know it is not a great idea to overpower, but I think this would be safe with the proper setup. Ofcouse I wont be hammering the throttle, as I am a fisherman and will constantly cruise at 3/4. *It is a soft Chine Hull, rounded bottom with a long bad.
Myself - 160lbs
Motor - 187lbs
Seats - 15lbs
Safety Gear - 20lbs
Carpet - 8lbs
Throttle - 5lbs
