gm280
- Jun 26, 2011
- 14,597
I think I'm using incorrect terminology. The motor looks like it sits nicely on the transom I think. The cavitation plate is probably half an inch or so below the bottom. I don't think I need to raise it up higher on the transom. What I was trying to describe was how I changed the location of the trim pin that adjusts the angle of the motor to the transom. I guess I should say I adjusted it out from the transom a bit so the angle between it and the transom changed. Not sure how to describe it. :lol:
Oh you did describe the tilt of the engine to the transom with setting out a couple holes. I totally understand that. I was merely stating that if you raise the engine on the transom itself you will gain top end speed and even more stability and handling the boat. And since you stated that the cavitation plate is sitting lower then the bottom of the hull, you really could raise it up some. JMHO
