Popular Mechanics 1962 PM38 Build [SPLASHED 2017]
pekstrom
Hi All,
This past summer the wife and I decided that a little boat would be fun to tool around the lake we have nearby. While shopping around for a small used boat I came across some information about the PM38 published in Popular Mechanics back in August of 1962. Both of us liked the design so I got this crazy idea of trying to build one. I have never done anything like this before, although I did take wood shop back in school many years ago. From the start I decided to take it slow and possibly have it ready by summer 2016.
For anyone not familiar with the PM38, you can look here to see information about it.
So far I have the transom, frames #2 and #4 as well as the stem ready. I have also prepared the keelson and the A-frames so the next step is to start assembling those parts. Once that is complete the chines are next. So I haven't made it too far yet. I am building it in my garage and because the temperatures are dipping down around freezing I have to take a break until it starts getting warm again. The glue needs at least 55F.
In the meantime I am shopping around for the items I will need to be able to take her out once she's finished. So far I have the following:
- A Kainer steering wheel from the 1950's with the drum for pulley/tiller type steering.
- A set of pulleys for the steering system.
- A 1980 25HP Mercury outboard with electric start and the MerControl remote control.
I still need a pair of control cables for throttle and shift and a few other minor items that I will pick up as I find them.
My plan is, once the hull is ready, to cover it with a few coats of epoxy resin and then a couple of coats of a nice marine paint to protect the resin from the sun.
I also decided to thicken the transom a bit by adding an extra sheet of plywood. Other than that I am trying to stay as true to the original plans as I can. The wood I am sourcing from a local lumber yard who carries marine grade plywood. They don't carry Fir lumber so I have opted for Ash which is nice and strong.
Well, that's it for now. As I progress I will add updates here but for now I don't expect to continue with the build until March or April time frame.
Transom:
Click image for larger version  Name:	Transom_1.jpg Views:	2 Size:	180.5 KB ID:	10096948
Frame #2:
Click image for larger version  Name:	Frame-2.jpg Views:	2 Size:	238.9 KB ID:	10096950
Frame #4:
Click image for larger version  Name:	Frame-4.jpg Views:	2 Size:	232.2 KB ID:	10096952
Testing how the pieces fit together:
Click image for larger version  Name:	TestAssembly.jpg Views:	2 Size:	229.3 KB ID:	10096954
Steering Wheel:
Click image for larger version  Name:	SteeringWheel.jpg Views:	2 Size:	186.6 KB ID:	10096956
Mercury Motor (needs new decals):
Click image for larger version  Name:	Mercury.jpg Views:	2 Size:	205.9 KB ID:	10096958
sphelps
Looks like a fun project ! I'll tag along for the ride !
Good luck !:)
jbcurt00
Is the 80s Merc setup to use cable/pulley steering?
Otherwise, nice looking 60s plans, great for 2 up cruising.
Look forward to seeing progress
GA_Boater
Good start on a boat you will call all your own. :thumb: She is gonna be a nice little speedster. Good to another woodie project, we don't have many.
iboats has all the pulleys and springs you need. The only thing you might have trouble finding is the bracket for the steering arm on the Merc. You have time to find that or easy enough to fab up if you can't find one.
We have threads with diagrams of how to rig the cable/pulley steering, too.
pekstrom
Yes, the motor has the bracket in the front where the cable/pulley connector attaches. So it is all ready for it. Now I just need the boat finished. :)
Ned L
Very nice!!!
A couple of things. Nothing wrong with traditional cable steering, just be sure to through bolt all the associated hardware, pulleys etc (NO wood screws).
Do you still have a chance to make a change on your plywood?...... Ash is not all that rot resistant (a bit surprised you were able to find ' ash marine ply'). I personally would go with just Doug fir ACX over the ash.
You have a good start on it,.. Enjoy!
As for covering it with epoxy, you will need to incorporate some glass cloth in there, 4 or 6 oz cloth set in the epoxy would be fine.
bonz_d
Now that will be cool. My very 1st boat was a 12' plywood runabout that had a late 50's 18hp Evinrude with cable steering. Gee, that was way back in 1966-67.
pekstrom
Ned L, I had pondered how to anchor the pulleys etc. and you confirmed what I thought would be stronger and better. I don't think I will go through the hull but definitely the frames and I may go through the transom to make sure the pulleys stay in place. Also, I am using Ash for the non-plywood parts inside the boat. Come to think of it, I don't actually know what the plywood is made of. :) I do know it is marine grade so it should be good. You think glass cloth will be needed? I have seen others not do that and still get a good results.
Thanks everyone for the kind words! I'm looking forward to take the wife out for a ride and the kids to fish.
jbcurt00
IMO, you could probably just use cloth across the corners and joints as a compromise between total coverage w cloth and not using any cloth.
Thats the only place I used cloth on my small knock down kayak/canoe project. I wasnt using epoxy though:
http://forums.iboats.com/forum/boat-...started-it-all
Adding cloth to the epoxy will make it a more rugged boat in general, plus it will resist bottom damage more then epoxy alone would.
Last wood boat I followed during construction used fairly lightweight cloth everywhere but the bottom and up about 6in above the chine. There he used a couple layers of a heavier weave.
The bottom was painted up to the waterline, so any hint of the cloth was well masked. The lighter cloth everywhere else went clear w epoxy, so after multiple coats of varnish/poly/spar it you couldnt see it either. Just the nice mahogany planks.
I dont recall how Sean handled the epoxy w or w out cloth, but it was a fantastic build:
http://forums.iboats.com/forum/boat-...ild-crackerbox
Warning: be prepared for the ending, Sean's project was lost at sea.
How are you sealing the frames and etc that make up the framework?
pekstrom
jbcurt00, I may reconsider on the cloth then. I'll take a look at those other threads you included the links for. As far as sealing the internal frames etc, I had planned to just use epoxy resin and then paint over that to add UV protection. Is there a better way I should consider? I have also planned to make some flooring out of some 3/8" or 1/2" plywood so we're not stepping directly on the inside of the hull and the battens.
jbcurt00
Epoxy and paint sounds good for the frames and etc
If you dont have 100% of the lumber for the structure yet, might consider white oak instead of ash. But it has to be white oak. Lots of genericly described oak, is red oak because it tends to finish better. Red is not a good choice for boat building.
If it was mine to build and I could afford it, a slat deck out of mahogany would be my 1st choice.
pekstrom
When I got started and couldn't find Fir I had read Ash was suitable for boat building and went with that. What is your main reason for suggesting I use White Oak? Is it durability (as in rot resistance etc) or is it that the hull wouldn't be strong? I have bought some of the lumber and will need more. I have a piece of Ash for the keelson but could get Oak instead if that would help make the hull stronger. I also need lumber for the chines and could go with white oak there as well. How does it bend? It is fairly easy to steam bend?
jbcurt00
Does the plan suggest steam bending?
White oak steam bends into a much tighter radius then ash would, w fewer fracture/failures.
White Oak is more rot resistant then the ash, and for parts and pieces that will be buried in the structure of the boat (hard to remove/replace) I'd use it over ash.
Woodonglass
Ash is NOT all the bad for boat building. Just depends on where you'll be using it. I think you'll find this an interesting read...https://www.glen-l.com/wood-plywood/bb-chap5c.html Since all the wood will be epoxy encapsulated it's almost a moot point nowadays. As long as your joinery and building techniques are sound the boat will be a seaworthy vessel that will last for a good long time as long as you exercise proper care and maintenance.
What part of the country do you live in? What are your most common Native types of wood? Do you have any local sawyers/mills where you can get quartersawn lumber?
pekstrom
Yes, the chines need to be steam bent as well as some of the plywood in the front and the sheer and spray rails. So based on what you are suggesting I may use white oak for the chines, keelson and bottom battens for sure. They would be difficult to replace later. Thanks for the tips and information!
pekstrom
Woodonglass, I live in the northern half of Georgia in the US. We seem to have many types of trees growing natively in this area and Ash is one of them. I have a lumber yard locally where I have bought my lumber. Not entirely sure but I'm thinking they flatsaw their lumber. Everything I have gotten from there has been nice and straight. I am taking it slow and try and think through what I need to do, and also to make sure I get things like joints nice and tight. I have used Ash for everything I have put together so far (except for the marine grade plywood) but if it makes more sense to use white oak for the types of things jbcurt00 pointed out then I'm thinking I might do that.
Grandad
Boy, that brings back memories. I built a "Minimost" hydroplane from plans in a 1962 Popular Mechanics when I turned 15 that year. My dad taught me a lot during our earlier build of a "Jazz Baby" model, also a Popular Mechanics (or Mechanix Illustrated?) project. http://www.svensons.com/boat/?p=HydroPlanes/minimost
Enjoy. - Grandad
Ned L
I would not be concerned about using ash for the frame. Oak would add a good bit of weight that you don't need. If the boat was designed for fir then there is no need for oak.
Ash stem bends nicely also. Any wood that you are interested in steam bending should be green, and certainly not kiln dried (which is all you can get at anything close to a big box store.
Keep in mind that "epoxy" is a glue and really benefits from the strength of the glass cloth.
...Hmmmm,.... "Steaming plywood",... That could be interesting.....
Ned L
No Title
Here is a piece of white oak, to give you an idea of what can be done steaming.
gm280
pekstrom, very interesting build. Mine if I tag along as well? I like your plans and want to see this one through. :thumb:
A little story about white oak. A lot of folks don't know it, but the usual delivery of sewer piping for the usual county, city projects is delivered with white oak securing the pipes together as they are off loaded on the side of the highways. And that is because white oak is so resistant to rot. So it literally can sit in mud and dirt for months and months without any effect to the wood. And then they use the pipes and throw away the wood to the dump. I know this because I actually got some of it from them and it is very good quality material.
I got 4" x 6" x ?' lengths rough cut and will take any of it I can get from them. White oak is solid quality hard wood and can be used for so many projects. Just some info about that wood.
If you have to steam the woods needed for the keel, the old show on TV "New Yankee Work Shop" with Norrn Abrams did a few shows on how to bend and even build a steamer. Might research his methods and steamer. JMHO!
