NWVintage
Thread starter- Joined
- Aug 8, 2011
- 65
So, my drain plug has never seated 100%. It's always gone in snug but has always leaked a very small amount of water if I didn't wrap it several times with thread tape. It turns out that the fitting was cracked! I'm replacing it and I am wondering if there's anything that I out do to treat the wood that's exposed between the fitting and the drain tube. I've inspected closely and it's not rotten but continued exposure doesn't seem like the best solution... This is for a fiberglass boat with a wood-core transom. The drain tube is about 1/4" too short to reach the back of the plug fitting. Do I need a longer drain tube that makes contact wit the drain plug fitting? All will be bedded with 5200 but that little space between the two literally ALWAYS has water in it and that seems like a bad situation...
