BWR1953
Thread starter- Joined
- Jan 23, 2009
- 6,626
Oh sure, now ya tell me! :lol:I wouldnt use the stripper wheel on anything other then a but of soft paint left behind after scrapping.
Thats stuff is still nasty and you dont want to fling even a little bit off w the wheel....
Stripper needs to go down in 1 smooth stroke. No brishing back and forth and no smearing it around....
Initial contact seals out air and re-brushing 'lifts' 1st coat and prevents it and 2nd coat from working quite as well.....
Do smaller areas on opposite sides. Apply, cover, move to the other side, apply cover and wait 20 min then go and scrape 1st side, then 2nd....
If its still not great results, apply, cover and wait 30min try again.
I think some have left it 12hrs or longer to let it really chew on the paint.
Also when covering, dont smoosh/wiggle or press plastic down too much. It might be doing the same as re-brushing and hampering effectiveness.
If all else fails to improve reaults (tried the flour trick yet?) step up to a nastier stripper, like airplane paint stripper. It is probably best not to let your son apply, help cover or remove it though.... At least not the 1st few times you use it. Rusto makes a good one, but I used the brand sold at my local auto parts place...
The details you provided make sense. Lots of good, helpful information. Thanks! And based on that info, I can't help but wonder if the ideal way to apply the stripper would be to spray it on. Ya know?
So after my earlier post, we tried a couple different techniques with improved results.
In this pic, we applied to a smaller area adjacent to the previous poor results section. This time we brushed on a thick coat, covered, waited 20 minutes and scraped. Worked better than the prior method.
The section in the foreground was the second attempt.
For this attempt we poured a large portion then spread with a wide scraper. Didn't cover it. It bubbled up quickly. Waited 15 minutes.
Scraped again this time. The section towards the bow had been done previously. Some stripper dribbled down the stern and did well.
Then we took it outside for a rinse with the pressure washer, which also cleaned around the rivets very nicely.
Back in the barn, ready for more work tomorrow!
