Hi everyone.
I have a 1993 Johnson 115hp 2 stroke (model VJ115TLETS) that isn't firing on one cylinder. Every time I remove the spark plug it's fouled really bad. I have replaced the plugs, coil and leads but still no spark. I am going to swap the power pack today and see if that helps. I have downloaded the pdfs from CDI on troubleshooting the stator and timing base. They are well over $300 each at the local Johnson supplier so I want to be absolutely sure that they are faulty before replacing. I am just wondering if there is anything else to test/troubleshoot besides these.
The motor idles real smooth at about 1000 rpm. But at WOT I am only hitting about 4800 RPM and not getting any real speed. This motor is on a 24' pontoon and I am not expecting high speeds, but with two people in the boat I should be getting more than 10-12MPH. It also hesitates while giving it any kind of throttle. So I am assuming that being short a cylinder would cause this.
Any help is appreciated.
