Under Construction: Bateau.com TW28 Stretched
Status
Not open for further replies.
I would be half tempted to fill the bubbles up with epoxy and ground fibers thru a syringe
KnottyBuoyz
It's kinda big. About 8" dia. I'm ashamed to show it it's so bad. I would have to hang my head in shame! :faint2:
I'll just cut it out with the die grinder and patch it. That area will eventually get filled with goop & wood flour so it's not a cosmetic issue.
our carbon fiber guy uses what he calls "yougurt". resin and milled fibers that he does his filleting, etc with. Hence the thought.
no need to hang your head in shame.
KnottyBuoyz
So today's tasks in the shed were fixing a bubble, aligning some stringers and setting some frame/bulkheads in place. Lot of naval gazin' went on with plenty of ponderin' too!
Web log updated: http://she-kon.blogspot.ca/2015/09/bubb ... heads.html
Sanding day & possibly bedding the stringers (aft section) tomorrow.
Standby.....
KnottyBuoyz
It's happening man. All that time consuming hull stuff...it's almost what makes it a boat or something. :)
“"Nothing in the world is worth having or worth doing unless it means effort, pain, difficulty." - Theodore Roosevelt
Thanks for looking in sprintst. :)
KnottyBuoyz
Morning briefing.
The stringers, like everything else, want to slide down the hull into the keel. With every step I take in the boat they work their way downwards and away from the transom. So this morning I lined them up again and am welding them to the bottom.
Using slow hardener on a cool day so it'll be awhile before I go and put some tape on them. Once this cures up I'll be able to move around the boat without worrying about the stringers migrating to the bilge.
Standby....
I would put your bulkheads in place to hold them
KnottyBuoyz
There's two in there now.
Plus a spacer at the other end. I measured 15 times before I glued! :D
Just finished taping the spot welds. Should be good to go tomorrow with more bedding. Man it's hard on the hands though. Wrist splints & Aleve tonight. Or maybe more Rum, I dunno! :faint2:
Remember,if you drink rum in the morning, it doesn't mean your an alcoholic, it means your a pirate
kcassells
Knotty,
I haven't commented in here for awhile but have been watching.
You b kicking some stuff and lookin great! Just so you know...I don't know where you get the energy, $$ or whatever but the work is aces and an inspiration for all of us.
:llama:
You are kickin some of the above....that's not a lima lol
KnottyBuoyz
Back into the shed after some family business & nasty weather got in the way. Mixed up some goop and bedded the aft section of the stringers in place. This is really hard on my hands mixing glue so I pulled the ole' Lady's hand mixer out of the kitchen and whipped up a few batches! :faint2:
After some putzin' around I managed to get the aft section of the stringers bedded, filleted and taped (just one layer before my hands gave out).
Fillets turned out pretty good this time. I used a cut up bondo squeegee.
A few more pics & such on the blog update today: http://she-kon.blogspot.ca/2015/10/bedd ... ngers.html
Standby....
littlerayray
Good idea with the mixer and hope
I hope the weather holds out its turned cold this week fall is in the air hope you can have at least 2 more months of decent weather before you call it quots
Status
