83mulligan
- Feb 7, 2009
- 687
Re: Upon Further Review..#$%@..1973 Slickcraft Trans/String Overhaul
Terry, i'll definitely be making a a pb mix for round 2. I was not impressed with the PL. I scraped a lot of the skin last night. The PL peeled off in sheets. The places where i poured epoxy from the top will need to be ground off. I don't know if i got some bad PL or what, but I'll be using epoxy PB from now on because if this experience. I know many have used PL successfully, it just didn't bond well for me and i know i did the proper prep work. Even the spots where i got good clamp pressure and contact peel easily.
Hey 83, sounds like a tough break. Glad you have a plan to go forward.
Have you thought about using a PB mixture, made up just a little looser than PL so it flows and clamps easier? Not trying to throw a wrench in your works, but thats how I did mine and had plenty squirt through all the holes and around the edges.
Then again, a nice thick layer of PL would probably do just as well...you are using the super sized 28oz contractor tubes right?
Terry
