Re: 1986 Landau Bowrider restoration
Trying to determine which to use, glass or epoxy at this point. The fun part is going to be removing the cap I think, as the Bow on this is ALL fiberglass from the cabin forward. I was working on removing the carpet that I could see from inside the front 2 wells, when I realized the factory installed the carpet under the cap as well... I will not be doing the same, that is for sure.
Going to have to clean out the garage too, as I am sure the city is not going to like an eyesore like this outside much longer.
Another thought I was tossing around, When I was stationed in Okinawa we were having a heck of a time keeping any type of wood on stake bed trucks, or in flat bed trailers. Due to the large amount of salt air, even 1/8 diamond plate was rusting through in less than 2 years. So they ordered in Plastic lumber. Now I am still researching this, but about the only drawback I can see would be is the weight of it. But it would also eliminate the need to glass it all in, as the lumber is not subject to rot like the wood is. This idea is for the stringers only, as a full sheet of 4x8 is over the $200.00 mark so the deck would not be worth the cost. But you would never have to worry about the stringers again.
