Re: my 1991 capri rebuild
sorry i havent responded the last few days. the rink i manage hosted a charity hockey game to raise money for cancer and this last 5 days has been crazy, thats the main reason pics were not posted when i was asking for ideas. i appreciate everyones input and suggestions. ive learned that boat building requires basic skill, but advanced determination and the ability to identify issues and find a sensible way to rectify them ha. anyways here are some pics for the past two weeks:
after cutting the stringers, knees and bulkheads i put a first coat on them in the basement since it was about 20 degrees that night outside
the next day it was MUCH nicer out and about 65 degrees so i moved everything outside and attached the knee reinforcements to the stringers with csm. the knee braces now consist of the 3/4" clear pine stringer with a piece of 3/4" marine ply on the inside and outside. the inside brace was designed to be buttressed against the rear bulkhead
i couldnt find my other speed clamps at the time so i removed the vice from one of my work benches and used that to help clamp
so this is where everything went to BLEEP. things were glued in well with pl. i was just going to wait for it to cure, sand, and then tab, but then i realized the mistake.
so after allot of thinking i decided to execute my plan. i dont have pics bc i was so rushed for time, but i cut my 1x1"s length wise to sit on the hull to simulate the deck, i then screwed the stringers to the 1x1"s to suspend the stringers above the hull. next, i took a piece of csm, wet it and laid it the length of the stringers on the inner side. its only purpose was to act as a barrier for the resin mixture i was going to pour from the outer side of the stringers which would fill the gap i had. the plan worked perfect.
