knockin 4.3 mercury
brad24
My engine started knocking sound like a rod but it goes away and I only hear it when am at full throttle and trimed up after I trim down and let off a little it slowly goes away. It was begining of the season was thinkin maybe bad gas I ran it out nowbut kind of sscared to fill it up and try it again any ideas
OldNBold51
Re: knockin 4.3 mercury
it may be the u joints in the outdrive knocking when you have it trimmed up but disappears when you trim down.
brad24
I have to back off the throttle for it to stop knocking and it takes i couple mins to stop aftet i back off but it starts as soon as I trim up
bonzoscott
Try full throttle without trimming up. If you still hear it, probably a rod.
Watermann
Trimming the outdrive up or down won't make or stop a rod from knocking. Make a video of the motor running so guys can hear what the sound is your concerned about.
Volphin
Uh, no. Bad gas will not sound like a rod knock.
500dollar744ti
Not always, rod knocks can come and go with changes in engine load and oil pressure, I've seen a lot of weird stuff.
If the rod is knocking at idle, disconnecting the ignition lead to the cylinder that's knocking will cause it to quiet down or completely go away, then you know it's a knock for sure.
What's your oil pressure like, that can tell you a lot.
old islander
I'm betting on a u joint....but I lose every time I go to a casino.
Volphin
Ayuh,.... But, Bad gas causes Detonation rattle, which leads to a rod knockin',....
It sure does! Detonation will kill an engine quicker than you can say gasohol. LOL
brad24
Ran the boat this weekend put new gas in it and fuel treatment it did not knock at all even at full throttle trimed up so must have been the gas
