ifallsguy
- Sep 12, 2009
- 160
Re: tail lights not working
follow the white wire from the trailer side of the plug. It should run to a screw attached to the trailer. Then follow the white wire on the Honda side of the plug to where it physically grounds. Make sure both of these connections to their physical connections are clean and tight.
Normally you would ground the lights to the trailer frame, which is grounded, via the electrical plug (connector) back to the tow vehicle and battery. Having been through this, my money is on the ground wire from the plug to the trailer frame is the issue.
And check the plug set. A bad connector there will give you all sorts of issues, from some working lights to intermittent lights to no lights.
