mrainey889
Thread starter- Joined
- Apr 8, 2008
- 34
Question about props... I am currently running a 20pitch 4 blade mercruiser prop I purchased last year from a local boat shop. My boat is a 1990 Rinker, 18.5' runabout, with open bow and a 4.3 175hp (2-barrel carb) engine, Alpha I outdrive (1.81:1). I bought this boat used 3 years ago this month. I used the prop that came with it up until last May. The original prop (definitely not the manufactures by the way) would net me a top speed of about 36mph on the GPS. The motor definitely sounded like it was tacking out...however I did not know for certain because my tachometer does not work. I figured this was not good, so I took it easy on the boat (avoided WOT) and the next spring I purchased a 20p 4-blade at the recommendation of my local shop and went out for a test run. My top speed moved up to 46-47mph GPS indicated and the motor no longer sounded like it was going to fly apart. My hole shot as also more than adequate for my usage. I was very happy with this situation and drove the boat all summer in this condition. Towards the end of the summer I got the itch for a little more speed (and economy...rationale, 30mph at x rpms vs 30mph at a lower rpm would be better I would think...) I hooked up a dwell tach to my engine and went for a ride. I found that at WOT I was turning 4600 to 4700rpms. Since my engines spec'd max range was 4400 to 4800rpms, I felt I could move up a little in pitch, especially if I dropped from a 4 blade to a 3 blade.
So, I went to my local dealer and told them I wanted the next pitch up in a 3 blade. They told me that would be a 23pitch, and that my engine could not swing that prop. In other words, they refused to sell me the prop I wanted unless I was willing to sign off on not being eligible for a refund/exchange.
Here is my delima. I typically travel lightly loaded. I have my 20p 4-blade if I ever want to pull a tuber or skier. Based on what I have read here I believe I can run a 3 blade 23p no problem for most days. Should I ignore my local shop and go ahead and buy a 23p 3 blade prop on the internet? I ask this because the prices on the internet websites I have found beat the $200 price tag my local shop is asking.
Is anyone else running a boat like mine with that setup? If so, what has it gotten you?
While looking at props online I have come to another realization. What diameter should I purchase...there are several choices.
Any help/thoughts/critiques would be greatly appreciated.
Thanks,
Mike
Thanks,
Mike
