Yazoo 1415
mist92
I purchased a 1976 1415 Yazoo flat bottom boat and the plate with the information on weight capacity is missing. Does anyone have that information? I would appreciate anyone's help.
jbcurt00
Find a 1415 flat bottom w a 10hp limit and figure yours is about the same, as long as both are about the same Guage of aluminum.
my grandfather had 1 that was THIN aluminum, like nearly soda can thickness... but we caught fish and managed to rocky shore beach it hard & frequently w out punching a hole in it.
3 150lb 'people's is about max capacity I'd bet. Depends on freeboard and hull design....
mist92
total weight is probably 550-600#
Scott, I hope you are right. I have been unable to find any info about my boat I know the dry weight is 100 pounds and max hp motor is 10. I am concerned because I weigh 270 pounds and my wife weighs around 150 pounds the 100 amp battery is 62 pounds plus whatever the 50lb thrust Minn Kota weighs. I cannot buy a bigger boat at this time. Thanks for your impute
