yamaha wiring short
ford3853
A freind and I bought 90hp yamahas #90tjrz.<br />We both mounted them on all aluminum boats.<br />He runs a straight 12 volt system and I have two 12 volt batteries in series to run a 24 volt trolling motor. One of my two batteries also serves as my cranking battery.<br />On seperate occasions the steel corrosion wire attached to the motor mount on the bottom unit of both motors has burned in two. :( Can anyone help us?
Trent
Re: yamaha wiring short
This is going to be a hard one on the internet. Several things to check. Would like to see a diagram of how you have it wired? Charging system working ok? Your anodes look ok? If it were me I would add a battery selector switch or an isolator to the system. DO you keep it in the water? Using it in saltwater?
