Yamaha VF115 SHO prop quote
ElDave
Hi There
I have a 2018 Yamaha VF115 with a 19p stock yamaha prop. It revs right to 6400rpms at about 3/4 throttle and gets me to 47mph. I feel i need a 20P but having a hard time locating the right prop that fits right onto my VF115. I would like a Turbo 1 or Laser II prop.
Can someone help get me a link or quote me the prop i'm looking for?
Texasmark
Hi There
Go to the top of the page and under parts go to props and fill in the blanks and a list of applicable props will show up.
I ran your posted RPM numbers assumning the F gearboxes are equal to 2 strokers in that hp range....but just speculation...... and you have something tangled up:
I ran a 20p, 3 blade, SS Laser II early edition on my 17.5' Crestliner Fish Hawk (aluminum with reverse chine and 12* dead rise at the transom) right at my WOT rev limiter of 5250 on my 2 stroke 115 Merc and was puckered up to kiss it but never could, even on a cool day, touch 50. I'm running a 4 blade 19p Solas SS currently at just over 5k RPM and running 47 on a cool day...with a 2:1 gear box....course the reason for switching was for cruising, not running all out. For that I would have kept the Laser installed.
Your 6400 at 3/4 throttle doing 47 with the 19P is very strange and your slip of 19% is really high for that pitched prop turning with engine RPM of 6400 and at 3/4 throttle to boot.....the pieces of the puzzle don't fit together so it's hard to help you with a solution.
Welcome to I boats.
QBhoy
You’re surely on the rpm limiter there. Defo need more pitch. But you won’t know how much, until you’re off the limiter.
Texasmark
The 4 blade got me off the limiter so the 3 blade must have been right there.
Texasmark
Can someone explain how does number of propeller blades and blade angle affect performance of boat motors?
kabosu coin
Go to the top of this page and click on parts, props, tutorial. If you want an engineering evaluation, consult the www.
1. Fewer the blades higher the efficiency but higher vibration and a decrease in usable thrust...all else identical.
2. Prop thrust is the blade pushing against the water and is what pushes the boat, similar to a screw's threads pushing against the medium as it makes it's way through it. However screws usually operate in a solid whereas props don't.
3.Pushing heavy loads at slow speeds (for a given engine) means large diameter and shallow pitch...like gears of a truck transmission, in low gear engine revs a lot but speed is slow. Light loads and fast hulls make for small diameter props (engine dependent) with high pitched (usually highly variable across the surface of the blade to maximize performance at different speeds), laid back blades from the root (rake for bow lift at speed) with the tail of the blade bent in (cupping for better grip at high transom angles....which work with rake to get the hull up and out of the water.....at speed, not talking about a Sunday afternoon cruise type operation). Some really fast boats have the tail end of the prop chopped and cupped, called Cleaver props used in things like ocean racing.
4. Props are screws and they screw through the water at some angle (usually variable pitch across the blade with the blade rated for the average pitch). Since you aren't dealing with a solid there is a slip factor. Usually the factor has to do with the design of the prop and type of load its trying to push.
That's a few tidbits I picked up over the years for starters.
