Yamaha tachometer help
Donvirude1975
Hi guys, i got this little boat andi think the previous owner replaced the motor but never got the tach hook up. Its It's a 2008 yamaha 50TLR. There are two set of wiring from the throttle box that are capped off. Does the old tachometer work with this engine or do i need a Yamaha tach? Thanks
99yam40
how are we suppose to know what tach you are speaking of?
the green, yellow, black, and red are for the tach /gauges.
the other set is for remote control of the tilt&trim
Donvirude1975
[No message]
99yam40
My guess is they are not Yamaha gauges.
how about anyone else
but should still work, but that is just my guess
Donvirude1975
Can someone tell me how to hook it up to my current motor. I posted pictures of the wiring from my current motor on top
Donvirude1975
Am i correct that black is negative, blue is for light on the old tach? On the Yamaha control i have black, red, yellow and green, so i suppose black go to black, what about the other three?
99yam40
Red is 12V +,
yellow is key on power,
green is tach signal,
& black should be ground/negative.
what to hook them to depends on the tach.
see if you can find marks on terminals or a wiring diagram for the make and model of the tach
