kbkindle
Thread starter- Joined
- Mar 2, 2005
- 27
i have a 2004 200 hpdi yamie outboard. The tilt- trim switch has two parts to it ,one the elec. switch itself and a round piece of plastic that goes around the shaft. It is split and a screw thru it to tighten it down after you set it a position that will show on dash where motor is trimed . My guestion is to anyone who has changed this piece of plastic can you pull apart the plastic piece to go over the mounting bar or do you have to disasemble rod and slip it thru. I know that this is about as clear as mud , but if anyone has changed one they might understand me. thanks kb kindle
kbkindle@sugardog.com
